586,551 active members*
3,269 visitors online*
IndustryArena Forum > CAM Software > CamBam > Cambam real slow after Windows update
Results 1 to 3 of 3
    May 2010
    61
    I've had this problem a few times but it usually straightens out after a week or two but not this time. Running Windows 10 and when it does an update my Cb runs really slow. This time it hasn't come back like it normally did. I read somewhere that it might have updated to graphics drivers on computer and they aren't compatible now but I checked and the drivers on mine are from 2015. Any other ideas?
    Apr 2018
    133
    Re: Cambam real slow after Windows update
    [Note: I moved away from Windows some years ago and now my systems are mostly Linux Ubuntu. So my Windows experience is outdated.]
    One thing that comes to mind is that based on your description above is that Update may have resulted in a bunch of temporary files that clog up your drive and slow the system down. Deleting temporary files may help. Some reading on this issue:
    https://support.microsoft.com/en-us/...6-434b4d5b9a68
    https://www.howtogeek.com/743633/how...on-windows-10/
    If deleting temporary files helps, that suggests that you may have limited disk space available. In that case if you have programs and or data that you can move elsewhere to free up more disk space, that would be a good idea.
    May 2010
    61
    Thanks! I'll try that and see if it helps.
  1. Mach3 ESS Machine runs real slow
    By squirrel_41 in forum Mach Wizards, Macros, & Addons
    Last Post: 04-26-2020, 08:16 PM
  2. KmotionCNC... Did the windows 10 update kill you?
    By MadTooler in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-21-2017, 12:46 AM
  3. Friggin Windows Update
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 10-11-2012, 06:05 AM
  4. Edit dxf and update in cambam
    By grandpa jay in forum CamBam
    Last Post: 07-18-2011, 02:45 PM
  5. Lego CNC update (the real thing)
    By jwstolk in forum Charter Oak Automation Support Forum
    Last Post: 09-10-2006, 10:20 PM
