587,004 active members*
2,760 visitors online*
Results 1 to 20 of 23
    Apr 2017
    158
    built-in named parameters
    Is there a maintained list of PathPilot's built-in named parameters, more inclusive than the one at G Code Overview?
    I had been maintaining two different warm-up routines for my 770, one to use when it was in the High spindle-speed configuration, and one to use when it was in the Low spindle-speed configuration. Just recently, I discovered the #<_spindle_rpm_min> and #<_spindle_rpm_max> parameters, and I can use them to produce a single warm-up routine that adapts to its environment.
    I suspect that there are more such Tormach-specific parameters.
    Oct 2005
    1145
    Re: built-in named parameters
    There are LinuxCNC named paramters and then there are PathPilot named parameters and THEN you can also access the Hal side parameters/pin values.
    Just a thought, (;-) TP
    Apr 2017
    158
    Where is a list of the PathPilot named parameters?
    Oct 2005
    1145
    Probably no such list other than the few mentioned in the PathPilot Manual. Tormach is not big on giving out details of PathPilot.
    (;-) TP
    Apr 2017
    158
    Can we use this thread to build such a list? The only ones (not in the PP manual or in the G Code Overview) I know about are
    • the spindle-speed limits (#<_spindle_rpm_min> and #<_spindle_rpm_max>)
    • the absolute coordinates (#<_x_machine>, #<_y_machine>, and #<_z_machine>).
    What have other people discovered?
    Nov 2007
    2151
    Does the Linux cnc website not detail named parameters?
    Apr 2017
    158
    It does, but there are some not in the lists in Sections 3.4 & 3.5 of G Code Overview
    I've assumed that those additional parameters are specific to Path Pilot, but it could be that they are active in all versions of LinuxCNC, just not listed with the others. In any event, there are usable built-in named parameters that are not in the above-cited lists.
    Oct 2005
    1145
    You would need to search through all the PathPilot code to see if you could find where they created the Named paramaters and THAT is a lot of searching (;-). When I get time I will take a peek to see what I can find.
    (;-) TP
    Oct 2005
    1145
    I just did a fast sweep of the PathPilot codebase and the ONLY place I found "#<_spindle_rpm_min> " was inside of NGC programs. That would indicate that that Parameter was unique to LinuxCNC not PathPilot.
    Just a thought< (;-) TP
    Apr 2017
    158
    I wasn't hoping for a complete list. I thought that members of the forum could contribute whatever parameters they'd happened upon, and that the list could grow here over time.
    Apr 2017
    158
    Quote Originally Posted by vmax549 View Post
    I discovered #<_spindle_rpm_min> and #<_spindle_rpm_min> inside a .NGC program that appeared on my 770 after a PathPilot upgrade, but I don't know how that bears on whether those parameters are unique to PP or part of any LinuxCNC engine. For what it's worth, when I write gCode subroutines (for PathPilot, since I have no other LinuxCNC engine), I create them as .NGC programs.
    Oct 2005
    1145
    Indeed you do have a linuxcnc engine PathPilot runs on it . Yes that parameter use is in 2 Gcode programs written for spindle warmup. IF Tormach had created it it would have shown up in the Code somewhere beside those 2 progam files. In those 2 file Tormach just used the parameter it was not created there.
    (;-) TP
    Apr 2017
    158
    Right. What I said was that I have no other LinuxCNC engine.
    Aug 2016
    132
    _spindle_rpm_max and _spindle_rpm_min were specifically created to be used in the spindle warmup program of Pathpilot, they're not standard from LinuxCNC. There's never been a list of Pathpilot specific parameters made, the only two I remember off the top of my head are _pi and _epoch_time.
    Apr 2017
    158
    Quote Originally Posted by footpetaljones View Post
    Thanks. _pi will be useful.
    Apr 2012
    64
    If you search the PathPilot directory (~/tmc) using ^\s*self.params\[ as a regex, it pops up a list of the PathPilot created parameters. Most are in ~/tmc/configs subdirectories.
    Apr 2012
    64
    Predefined Linuxcnc named parameters are listed here: G-code Overview
    Apr 2017
    158
    Quote Originally Posted by gerritv View Post
    Yes; read posts #6 & #7 above. I was looking for PathPilot-specific ones, like _spindle_rpm_max , _spindle_rpm_min, _pi, and _epoch_time
    Apr 2012
    64
    Quote Originally Posted by Fenichel View Post
    I assume that you read the previous paost as well? a grep of ~/tmc with that regex will show you the defined globals for PathPilot (they all start with _)
    Apr 2017
    158
    I read it, but I haven't yet had a chance to fire up my 770 to check out those files.
  1. Replies: 2
    Last Post: 03-30-2020, 11:06 PM
  2. Asius Technologies Named 2013 Autodesk Inventor of Year
    By cncadmin in forum News Announcements
    Last Post: 02-26-2014, 08:20 PM
  3. Editing a named spline using a macro?
    By spacely in forum UG NX
    Last Post: 04-26-2010, 10:06 PM
  4. PBC Linear Named Leader in Engineering by Design World
    By Pacific Bearing in forum News Announcements
    Last Post: 12-22-2009, 10:04 PM
