586,804 active members*
6,459 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Xilog/Maestro/Aspire issue
    Sep 2008
    13
    Hi
    I have a problem running aspire on my SCM pratix S12.As seen in the videoclip there is an extra z movment in between two toolpaths, there is, in the ISO-file produced by MAESTRO a couple of rows that is + or - 140 mm, these rows are not in the XXL file produced by my Aspire postprocessor. Most likely these movements are added somewhere in the translation process XXL>PGM>PGMX>ISO but I cant figure out where it come from. I tried to attach the XXL/ISO files but I dont know if I succeeded.
    Any help would be highly appreciated.
    Attached Files Attached Files
    Re: Xilog/Maestro/Aspire issue
    On our Morbidelli X200, I've run one file that I created in Aspire, and imported into Maestro, and I believe that I saw a similar issue. I was running the .pgmx file directly, but didn't see anything in Maestro that could cause it. Never spent too much time looking into it, as I was only running one file.
    I usually just program everything in Maestro after importing .dxf files.
    Dec 2015
    Please upload the XXL or pgm file.
    Sep 2008
    13
    Here is xxl and pgm
    Sep 2008
    13
    Sorry, I meant ISO, the PGM is too big to attach.
