586,504 active members*
3,335 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Looking for Syil X4 standard, mach3 config xml.
    Jan 2021
    8
    Hello, I just acquired a 2012 Syil X4 standard with 4th axis and automatic oiler. I am looking for a Mach3 config that's up to date-and working with my machine.
    It's unfortunate that Syil doesn't support the x4 anymore, it really isn't that old in machine years.
    Apr 2024
    Re: Looking for Syil X4 standard, mach3 config xml.
    I need one of these too if anyone comes across it? Can get everything working except for the spindle from software. Otherwise have to manually turn spindle on select direction and set RPM before running code then manually turn it off when done. Is annoying
  1. Mach3 XML file for Syil X6 inches
    By Fernanocado in forum Mach Software (ArtSoft software)
    Last Post: 10-04-2019, 09:50 AM
  2. NM-145- need config file (XML?)
    By steveb946 in forum Novakon
    Last Post: 10-06-2016, 08:20 PM
  3. Standard ebay controller xml file
    By jimbo12d in forum Mach Wizards, Macros, & Addons
    Last Post: 10-24-2011, 02:51 PM
  4. Replies: 2
    Last Post: 07-19-2011, 05:18 AM
  5. SX3 - Mach3 - non standard pin config - no movement...
    By krazatchu in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2007, 05:45 AM
