586,565 active members*
3,794 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Can other S/W besides Mach3 support the CNCest 6040 CNC unit
Results 1 to 4 of 4
    Feb 2023
    6
    Hi Folks,
    Just wondering if a problem I have is related to MACH3 license , from China, as my programs just
    seem to stop dead at about 80%.
    Can other GBRL programs support whats in the CNCest 6040 machine does anyone know?
    I do have a mini CNC machine with the control board on the back. Turning on the spindle is a manual job
    and the machine uses GBRLcontrol for running the code...but it works ok via USB....
    Could I use the board on the 6040 I wonder?
    Cheers
    Richard
    Jan 2005
    15362
    Re: Can other S/W besides Mach3 support the CNCest 6040 CNC unit
    Quote Originally Posted by Richiek67 View Post
    Hi Folks,
    Cheers
    Richard
    Load the real Mach3 and buy the license!
    You will have to set it up with the same profile as the Chinese copy has, so write down all the configuration Ports / Pins Etc.
    Mactec54
    Jan 2018
    1516
    I downloaded the legit mach3 SW from artsoft, put my pirate lic in the folder, and it worked fine. I've never had a problem. Some do and some don't.
    Are you sure it's not just a bad code line?.
    I only use mach3 for simulations on my cad pc now. I use UCCNC kit on the actual mill.
    Feb 2009
    2143
    Non-licensed Mach3 will only run 500 lines of code, is that where yours is stopping? If so, buy a license and it will go to unlimited length.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  1. CNCest 6040 Spindle not working
    By Richiek67 in forum Chinese Machines
    Last Post: 03-14-2023, 04:45 PM
  2. UNITEK (Y-7508) PCIe-2S1P Works with Mach3 & CNCEST 6040 (LPT version)
    By zorro07 in forum USB, RS232, PARALLEL etc
    Last Post: 07-09-2020, 02:01 AM
  3. Replies: 0
    Last Post: 04-08-2020, 03:52 PM
  4. CNCEST 6040 SETUP
    By nextimemike in forum Chinese Machines
    Last Post: 01-13-2020, 10:09 AM
  5. CNCEST 6040 CNC Comissioning
    By JohnLeslie in forum Chinese Machines
    Last Post: 01-24-2019, 01:53 PM
