587,035 active members*
3,167 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 4th axis speed limitations
    Aug 2010
    190
    currently running a MA650 mill, with an OSP200M control and a tsudakoma 4th axis, we are machining some small auger sections but we cannot achieve the feeds we would like. when the desired feed is programmed, the machine alarms out 4204 ALARM D FEEDRATE COMMAND LIMIT OVER (REPLACING)10000D3B. any help would be appreciated.
    Jun 2015
    4156
    Re: 4th axis speed limitations
    hy jay check attached : longword10 to be > in program value
    Jan 2013
    474
    Quote Originally Posted by jay_dizzle View Post
    Remember, rotary axis cannot keep up with linear axes, xyz feedrate and rapid must be reduced to conform to maximum Tsudacoma feedrate if synced.
    Aug 2010
    190
    Hi, we just looked at long word #10 on this control and it is labelled as "maximum feedrate clamp value" and it is currently set to its maximum at 200000. our programmed feed rate is maxed out at 1000 deg/min, any more and the alarm occurs. my operator is saying that he suspects that the x axis is what is holding us back, he figures the value "F1000" is causing the issue
    Nov 2013
    4470
    if I'm doing normal three axis milling in brass say I commonly use feeds around F= 600mm/min.
    If I'm doing a rotary job on the fourth axis , say 20mm diameter then I want it to spin near the max speed of the fourth axis, 150rpm.
    So F=5400 (degrees/min). Potentially that would mean that the X,Y,Z axes would also do 5400mm/min, but because the linear axes are coordinated with the rotary axis
    it's effectively the rotary axis which 'throttles' the toolpath.
    Craig
    Jun 2015
    4156
    long word #10 ... it is currently set to its maximum at 200000. our programmed feed rate is maxed out at 1000 deg/min
    hy jay i am not sure if feed as deg/min is the way that the rotary axis deals with, or that you can compare 1000deg/min with that long word
    there is too much of a difference between 200000 and 1000
    there is something with rotary axis; i solved it for lathes ( c cx cz cxz cxzy ), so i can try also for mils; i'll send you a pm / kindly
  1. Limitations of cheap 4th axis components off eBay?
    By Goemon in forum DIY CNC Router Table Machines
    Last Post: 09-17-2019, 07:03 AM
  2. Replies: 19
    Last Post: 06-07-2016, 05:54 AM
  3. 4th Axis rotation speed
    By LRF in forum Tormach Personal CNC Mill
    Last Post: 04-23-2013, 01:04 AM
  4. Speed up 4th axis?
    By compunerdy in forum Tormach Personal CNC Mill
    Last Post: 04-01-2010, 06:06 PM
  5. How do I synchronize 4th axis speed with X,Y,Z?
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 08-02-2005, 02:42 PM
