586,993 active members*
2,878 visitors online*
    Mar 2007
    5
    Exclamation Anilam 5000 Motion Control Card Fault
    We have a mega mill using the Anilam 5000 control with a 4 axis motion control card. A few days ago while running a cycle the machine spindle and the light switched off and then back on almost instantaneously. We ignored it at first since it did not do it again for a few days but now it does it every few minutes.
    On the control we switched the two I/O cards (the small ones that cables can0 and can1 connect to) and ran the cycle again, the problem persisted. The machine has a varispeed drive on the spindle and running it manually poses no problems at all, the fact that the light also switches off indicates that it must come from the control since it switches the light's relay on and off.
    There are only two more places I think the problem could be, either the main PC card that has the processor and memory on it or the main motion control board next to the pc card. Problem is the manufacturer will sell us either one but if it is the wrong one they will not take the card back and they are relatively expensive. Has anyone else had a problem like this with this type of motion control card? It would be a great help!
    Nov 2007
    45
    Angry
    i've got the exact same problem.
    machine has been standing for 7weeks no-one seems to know what is wrong.
    bought new motion card / did not solve the problem.
    reformatted Hdd / did not solve the problem
    replace Hdd with a new (old) Hdd / did not solve the problem
    load new ver software / did not solve the problem
    replaced a suspect power supply board / did not solve the problem
    took unit to another cnc machine / still had the same problem
    have u perhaps found the solution?
    regards
    dave
    May 2010
    Please help!
    Quote Originally Posted by anilam View Post
    regards
    dave
    Hi Dave:
    Please tell me where to buy 4200 Anilam Motion Board (P/N: 33001102).
    Thank you very much for your help.
    Brgrds.,
    Duong Ng
    [email protected]
  1. Anilam M control
    By Mark M in forum Engraving Machines
    Last Post: 05-23-2011, 04:39 PM
  2. Please help me! Fanuc 3T control Fault!!!
    By khuonglq_au in forum Fanuc
    Last Post: 06-22-2009, 04:58 PM
  3. Anilam M control
    By Mark M in forum DIY CNC Router Table Machines
    Last Post: 09-27-2007, 05:08 PM
  4. srevo card fault
    By harvard5 in forum Bridgeport / Hardinge Mills
    Last Post: 12-01-2005, 10:49 AM
  5. TurboCNC with PC Motion Card??
    By Al_The_Man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-06-2005, 10:41 PM
