OK i
ve got the Rockcliff plans ive stared the build i glued drilled & screwed, got the nema 23 equivallent motors but i'm stuck trying to find the 16mm Diameter W16(h6) Straightend and polished - Carbon Steel or equivallent as in my last post ive not got a lot of money (out of work with back injury) so money is tight i found out where to get the bearings (oillite) www.brammer.co.uk if anyone wants any, i have found this other place www.marchantdice.com but the steel from them is a lot more than what i can afford, there price is £85.86 US$175.25 AD$195. for the 6pc's
so i have look through the post & people are using tube so what can you use
i look forward to your reply because i have a lot to learn & plenty of time to do it?
thanks steve
