Well, I finished my belt drive and was all set to go crazy, but when I turned my mill on and tried to start the motor i got nothing. I have the power light turn on, and if I manually turn the fault switch it will go yellow and fault. However, I can not get the fault light to turn on like it used to. By that i mean if the forward or reverse switch is turned to either it would fault and the motor wouldnt turn. The potentiometer is going to have to be replaced because I ripped the knob right off the switch, but my question is, if its not the potentiometer what is it? I have a multimeter but dont know where to start testing and what settings I use on the meter. I would like to make this a methodical test where I test each connection first before I decide its the motor and but a replacement from grizzly.
