Hi, I am experiencing interference from my hitachi router's power cable. I have the power cable run next to the motor cables because I am using cable carriers. Is there any way to stop the interference without rerouting the power cable? If I have to reroute the power cable, then my cable carriers are pointless. I have shielded wire on all my steppers, but the shield is not grounded because grounding one end causes way more interference. Currently, my z-axis driver is the only one having trouble, and it is the only one that isn't a gecko. It is grounded to the case only, because an earth ground made it worse. My next step is to order some shielded power cable for the router itself. Will that make any difference? Any ideas would be appreciated. Thanks.
