586,798 active members*
3,380 visitors online*
Thread: Fanuc System
    Sep 2007
    8
    Fanuc System
    :drowning:
    Hi All,
    Thanks for reply to my last posts. actually im new to this field.
    I tried to upload programms to Fanuc 6M from PC through RS232 port. using many DNC softwares.
    I got alam called 086 . I check every thing according to replys i got from my last post.
    But still problem is there . Now i want to check this RS232 port and the build cable inside the fanuc system. how can i do that ?
    That fanuc cable inside system has 50pin i cant realize that port. ( the cable plug to mother board in the fauc system)
    Pls help me.
    Thanks & Regds
    Chinthaka
    Sep 2007
    371
    Comunication controller 6.
    You must find a DB-25 female plug in the machine, that is the port used o comunicate the machine with the PC.
    The larm 086 is because the control is not sensing the signal from he cable, this due to a bad port or a bad cable or cable configuration.
    Check that an let us know.
    Greg.
    Aug 2007
    793
    Quote Originally Posted by chinthakahk View Post
    :drowning:
    Hi All,
    Pls help me.
    Thanks & Regds
    Chinthaka
    My manual says: "When the optional punch interface is equipped, either C14 or C15 connector is provided on the front door of the NC."
    EIA RS232C interface
    C15(1) - protective ground
    C15(7) - signal ground
    C15(2) - transmitted data (TXD)
    C15(3) - received data (RXD)
    "C15" - plug
    "(..)" - # of pin
  1. Fanuc system 6M model B
    By Olsson in forum Fanuc
    Last Post: 01-29-2016, 09:31 AM
  2. Fanuc 5T System BTR
    By protyper in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-08-2007, 03:06 PM
  3. Fanuc 0 Mate System
    By L. Sakthivel in forum Fanuc
    Last Post: 05-26-2007, 01:26 AM
  4. Fanuc 6 system error 908
    By hidivsultan in forum Fanuc
    Last Post: 06-23-2006, 02:43 PM
  5. Fanuc system 10
    By kayleesdad in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-30-2006, 05:59 PM
