587,048 active members*
2,989 visitors online*
    Oct 2003
    208
    z axis direction question.
    the way my cnc table is designed the x and y axis both go in the positive direction when i tell the program (turbocnc) to jog in the positive + dricetion.
    my problem is when i tell the z axis to jog in the positive direction ( i have the motor mounted on top of the axis )in the program, it actually goes in the opposite direction on my cnc table.
    by default the motors turn clockwise when told to jog in the + direction.
    how do i set the parameters in turbocnc so that the motor turns counter clockwise when it is told to jog in the positive direction instead of clockwise?
    i am using a xylotex 3 axis driver and the motors that came with it.
    Apr 2004
    678
    You can also swap motor leads to make them go the other direction.
    Jul 2003
    196
    I'm going from memory here, but you can change the direction within the software. I believe it's the line "LowIsPositive=True", just change the true to false and the steppers will go the opposite direction. If it's not this line, then it's "IsActiveLow=True". I'm at work right now and can't tell you which line it is for sure, but I had to do the same thing on my machine.
    jgro
    http://jgroshoppages.blogspot.com/
    Is it only the wrong direction when you jog? Or does it go in the wrong direction while running g code as well? If both, change it in the software as mentioned above.
  1. A Axis and Step and Direction Spindle Setup
    By mklb in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2009, 02:19 PM
  2. MasterCam 4th axis project question
    By HomeCNC in forum Mastercam
    Last Post: 12-13-2005, 01:17 AM
  3. 3 axis stepper motor controller board - question
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-07-2005, 04:02 AM
  4. 4 axis control board question
    By cnctoolman in forum Hobbycnc (Products)
    Last Post: 04-01-2005, 10:30 PM
