586,584 active members*
2,640 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Low price simple 2D cad program
Results 1 to 12 of 12
    Dec 2006
    112
    Hello
    I´m looking for a low price 2D CAD program to draw simple designs directly on the laser machine computer, the only requirement is that its possible to first draw the design and then dimension it, like in Solid works and Fusion 360.
    Is there such a program?
    Nov 2013
    4431
    Re: Low price simple 2D cad program
    Fusion is free to hobbyists and startups, would that not do?
    Craig
    Jan 2016
    16
    LibreCad comes to mind---free
    deltacad---lowcost
    qcad--free and low cost?
    vic
    Dec 2006
    112
    Fusion is great and we already have a license for that but it's not suitable for the slow pc on the laser cutter.
    I haven't tried deltacad but both libre and qcad seem to not have the dimensioning capability, I have to specify startpoint and endpoint and so on and I I don't think that is so beginner friendly as I also want to recommend this program when we sell our cheap plasma cutting tables to complete beginners that just want to fast and easy draw simple shapes.
    It doesn't have to be free, 100-200usd would also be ok.
    And if there is a sheet metal module to add it would also be great.
    Jun 2015
    4154
    hy jeybee i have created 2d cads, definetly not requiring high computers
    i can make it suit your desire is not that kinky, just in a technicall manner ...
    as for the computational cost of actual systems, that is not real a need .... among the way, someone made sure that cam's require hardware; it is market move / kindly
    Jul 2018
    6410
    Hi JB - Try Alibre atom. Peter
    https://www.alibre.com/atom3d/
    Dec 2006
    112
    Quote Originally Posted by peteeng View Post
    Thanks that is a good suggestion.
    Dec 2006
    112
    I also tried Freecad which seem to have the dimensioning capability.
    Jun 2015
    4154
    hy jeeybee i no longer can send you a pm
    please, try deadlykittenstella@ gmail.com / kindly
    Nov 2015
    371
    Probably your best option at the moment would be Solid Edge 2D Drafting - link
    It is free for both commercial and noncommercial use.
    Nov 2012
    154
    What you're asking for is called a "parametric CAD", which means you're looking for SolveSpace. Free, open source, small single exe file, easy to use. Draw shape, apply constraints, when degrees of freedom goes down to zero you're done. Don't let the "3D" scare you - it can do that nicely, but you never have to leave your 2D workplane if you don't want to.
    Jun 2015
    4154
    hy jeeybee, as not being able to reply to you on private, i will do it here
    in the end, everybody does speed up, but only a few, not all, are being stoped by the police
    you can always use a remote terminal, that you simply disconect from if needed, and also use network to send programs to the machines; the source is no longer in the phisical shop. If configured properly, the time window to use it, is shorter than editing programs near the machine panel.
    the key is configuration
    as to what you may need, it possible that i allready have it, or at least the basics ; can also make it particular to your demands / kindly
  1. Replies: 9
    Last Post: 04-28-2016, 11:42 PM
  2. WTB MGN15H at very low price
    By Yaro in forum Want To Buy...Need help!
    Last Post: 08-08-2014, 09:52 AM
  3. IMTS exhibition there will be a low price
    By HAO MAU in forum Trade Shows / Webinars / Other Events
    Last Post: 09-11-2010, 06:03 AM
  4. 3 holes to drill, I'm looking for a simple and free cad program
    By NickLatech in forum G-Code Programing
    Last Post: 09-26-2007, 12:05 AM
