586,655 active members*
2,888 visitors online*
Results 1 to 8 of 8
    Sep 2007
    Offset crc error
    Our company has a 93VF0 displaying "offset crc error".
    The machine only boots tot he point of Displaying "Haas", "v4.28e", what looks like a date code, and the error message.
    Haas and our local service provider says that if the machine would boot all the way that error means low battery, but since it won't boot that our software is corrupted. They refuse to provide or even sell just the software. We tried getting the chips themselves or the binary files so we could flash our own chips.
    Both companies insist that the only way to fix the problem is by replacing the whole board at a cost of $1800.
    Has anyone encountered this problem or a problem similar and/or does anyone know of a way to reinstall the software besides re-flashing the chips?
    Feb 2007
    205
    Battery replacement
    They should replace the battery ... there is a connection above the old battery where you temporarily plug in the back up while you solder in a new one. Your machine is a bit old. Replacing the board and getting the software upgrade with it might be worth it though.
    Sep 2007
    The battery is fine at 3.3v. If it was just a battery problem we would have lost the parameter data. The machine won't turn on past the screen displaying Haas and the software version number. The keypad beeps when you press a button, but nothing happens and after so many key presses the beep changes to a long beep.
    Jun 2007
    35
    Check your low voltage power supply. Make sure you have +12, -12, and +5 at the processor. That could cause issues.
    Mar 2005
    1498
    070925-1855 EST USA
    HAASTech83:
    Provide some tolerance values. My guess is +/- .2 V on the +5, and maybe
    +/- .5 on the 12 V supplies. What are the HAAS specifications?
    Anyone doing this needs a good voltmeter.
    Also check for AC ripple. My suggestion here is maybe 5 to 10 millivolts, but I have not checked a HAAS power supply.
    Checking two computers with a Fluke 27 --- results are:
    Code:
                         V DC   MV AC          V DC   MV AC
      15 to 20 yr old    5.09      29         11.83      12
    HP 5 to 10 yr old    5.15       9         11.78      15
    Jun 2007
    35
    +12 (12 to 12.6) Depends on how many amps hooked up.
    -12 (-11.8 to -12.0)
    +5 (4.8 to 5.0)
    Most of the time you will see about half voltage on everything aka +6, -6, +2.5 when you see processor, mocon issues.
    The machine can run at lower but i always want to see the voltage on the higher end of my ranges.
    Feb 2024
    Hello,
    I have the same probleme in my Vce 1000
    You've find the solution ?
    Quote Originally Posted by Robert Sanders View Post
    Mar 2010
    1852
    Re: Offset crc error
    nearly a 20 year old post!
  1. Replies: 9
    Last Post: 06-18-2014, 03:16 PM
  2. P150 error when trying to use nose radius offset
    By WillRitter in forum CNC Swiss Screw Machines
    Last Post: 08-09-2013, 10:22 PM
  3. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 06-04-2012, 06:31 PM
  4. Tool offset with work offset
    Last Post: 05-28-2012, 09:52 PM
  5. ERROR MESSAGE; File disk offset....
    By L.Kiefer in forum Haas Mills
    Last Post: 12-06-2007, 02:41 PM
