586,693 active members*
3,065 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 230M turret won't index
    Hello!
    I am working with a daewoo Puma 230M cnc lathe, fanuc controller 18-T.
    I have mounted a parting tool way too long. I was precaucious, so that the turret would not index in the wrong direction, until one point a I made a manual mistake and the turret rotated in the wrong direction, and crashed.
    The turret remained stuck at the position where it is crashed, and now it is indexed between two tools, and clamped. It won't rotate freely. The machine does not give any alarm.
    Can somebody please help me how to reset the turret, because i don't have the service manual for this machine. Thank you
    Jan 2013
    474
    Quote Originally Posted by mrk_varga View Post
    Hello!
    The collision could have caused the turret to slip on the curvic coupling.
    Remove all the tools and bungs, release the ring of clamp screws in the turret and refit a tool block. Use a copper or dead blow hammer to correct the turret rotation position. You may have one or two taper pins with the machine tools, lightly drive these in to finally correct the turret position, tighten the turret clamping screws, then, very important, remove the alignment taper pins or serious damage could occur if another collision.
    Maybe the procedure is on line.
    Feb 2013
    788
    Hello!
    Indexing impact will not damage curvic, because curvic disengaged to allow index.
    Used K5.4 = 1 to allow free rotation. Unjam. Align and alter back to K5.4 = 0
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jan 2013
    474
    [QUOTE=dhardt;2538666]Indexing impact will not damage curvic, because curvic disengaged to allow index.
    Used K5.4 = 1 to allow free rotation. Unjam. Align and alter back to K5.4 = 0[/QUOTE
    If the turret was clamped it certainly can slip on the curvic, I didn't say damaged. Simply unclamping using the keep relay to rotate freely won't necessarily realign the turret.
    Feb 2013
    788
    [QUOTE=servtech;2538690]
    Quote Originally Posted by dhardt View Post
    Feb 2013
    788
    I believe we are in agreement. Indexing rotation crash will not damage/slip a curvic.
    Clamped curvic crash absolutely will damage/slip a curvic.
    When I read his comment, it looked like he had a long tool and was trying to not index the tool near the chassis...accidentally he did. Indexing the tool into the chassis would not move the curvic.
    https://youtu.be/7Ucg2v3jEgs
  1. Daewoo Puma 230M - X axis overload
    By Mtmont88 in forum Daewoo/Doosan
    Last Post: 10-25-2021, 11:15 AM
  2. need help with puma gt3100l turret index issue
    By trademark in forum Daewoo/Doosan
    Last Post: 02-16-2018, 12:01 PM
  3. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  4. Daewoo Puma 10 spindle won't turn on
    By xcbellx in forum Daewoo/Doosan
    Last Post: 08-25-2009, 05:40 PM
  5. can the tailstock be programmed on Daewoo puma 230m
    By Bigbill in forum Daewoo/Doosan
    Last Post: 05-25-2007, 01:38 PM
