586,385 active members*
3,312 visitors online*
    Feb 2007
    171
    Fanuc pulse coder pinout?
    Hello!
    I have a problem with Fanuc servo motor's pulse coder.
    Can anyone tell what means these pins in pulse coder?
    PIN
    14 O ( or 0 ) - I think it's GND
    13 +5 - That's easy, don't even tell
    12 A - A-channel?
    11 A* - second interlaced pulse for A?
    10 B - B-channel?
    9 B* -
    8 Z - Zero or home, why two?
    7 Z*
    6 C1 - These are four C's somekind absolute counter?
    5 C2 - Bits for what?
    4 C4 -
    3 C8 -
    2 +5
    1 O
    Pulse coder type is A860-0304-T112 2500P.
    Servo is about 1kw from '80.
    24223
    The A & /A etc are the same signal complemented, this is the noise prevention feature of a differential encoder, There is only one zero pulse or reference, just complemented as the others.
    The C1~C8 are AC motor comutation pulses these output a binary pattern based on the position of the armature.
    Al.
    Feb 2007
    171
    Thanks!
    Jun 2010
    Have a fanuc encoder need pin out to locate 5 volt and 0 volt. Encoder A860-0360-V501
  1. #23-305-DS8A Pinout
    By Richie800 in forum Hobbycnc (Products)
    Last Post: 11-15-2007, 09:11 PM
  2. DB9 pinout cabling
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-23-2007, 12:21 PM
  3. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum DNC Problems and Solutions
    Last Post: 04-23-2007, 03:55 PM
  4. Fanuc Pulse Coder
    By Derek.C in forum Fanuc
    Last Post: 01-04-2007, 03:24 AM
  5. DB9 pinout diagram standard?
    By nervis1 in forum CNC Machine Related Electronics
    Last Post: 12-21-2005, 06:52 PM
