586,395 active members*
2,920 visitors online*
    Aug 2007
    31
    Threading problem on Mori seiki zl-15smc
    So today at work i was cutting an M24 thread
    got everything setup and wrote a program. Ran the first part and threads were short by .5000?? checked my program it was ok??
    program was like this for thread
    N8T0808(M24-3 THREAD)
    G97S1000
    G0G54G99X0.975Z0.2M8
    M24
    G92X0.929Z-2.3F0.1181
    X0.909
    X0.884
    X0.878
    X0.863
    X0.848
    X0.833
    X0.813
    X0.808
    X0.803
    X0.8
    G0Z0.2M9
    G28U0W0T0M5
    M30
    To Make the Part write I changed to this:
    G97S1000
    M24
    G76X0.8Z-2.3R0P0663Q10F0.1181
    G0Z0.2M9
    G28U0W0T0M5
    M30
    Mori had no answer for my problem
    Does anyone?
    I Like G92 more then G76 and have used it many times on this machine to thread its alot faster then G76?
    Fanuc 16TT control
    Jul 2007
    60
    Only thing i can se is a g76 is a better threading cycle!!!
    hehehe...
    Jul 2007
    60
    PS...
    Dryrun, how do you make uot G92 is quicker than G76 ??
    with 76 there are less programming lines and you can set the cycle to make 2 or 3 passes
    ST
    Jul 2007
    60
    Oh P** !
    Sorry about the typo's its 4 45 AM! - Early start but brain still in bed
    Aug 2007
    31
    i have always had better tool life using G92 over G76
    with G92 you are not stuck with just a depth of cut
    it can change from one pass to the next
    if you are running high production simple programing is not always the fastest way Togo
  1. Mori-Seiki SL-3H
    By B_Bueno in forum MetalWork Discussion
    Last Post: 12-20-2011, 04:00 PM
  2. Mori Seiki Sv-503
    By mr-seiki in forum Servo Motors / Drives
    Last Post: 06-04-2010, 02:52 AM
  3. Mori Seiki ZL-15 Startup problem???
    By =ego= in forum CNC Machine Related Electronics
    Last Post: 06-26-2007, 09:07 PM
  4. mori seiki mill with a spindle problem
    By imwllc in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2005, 12:31 AM
