586,500 active members*
2,486 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > Anybody still here? I need some dimensions...
Results 1 to 5 of 5
    Feb 2009
    2143
    My machine has been dead about 2 years. Started a spindle motor swap and got lost, and then uninterested. I am back on it now, but it seems I have misplaced the bolt that holds the R8 collet in the spindle... Could someone measure theirs and put the dimensions in this thread? Most needed are the total length under the shoulder, and the main shaft diameter. If you know the thread that would be great, but it's standard R8 collet thread, so I can figure it out.
    Thanks in advance!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Feb 2009
    2143
    Re: Anybody still here? I need some dimensions...
    7/16 x 20 UNC thread.
    Dec 2013
    5717
    I guess that would depend on what machine you have. As you stated, the shaft diameter is 7/16, but the length is machine specific. Use a welding rod or something to measure the collet end to the shoulder, then add about 2x the thread diameter.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2009
    2143
    It's in the MikiniMech forum - they only made one machine size.
    Feb 2009
    2143
    Meh, just bought some Grade 8 threaded rod and a hardened nut. Will pin it at the right height and cut off the extra.
  1. Replies: 1
    Last Post: 06-21-2022, 11:00 PM
  2. Inside dimensions bigger, outside dimensions smaller Mach3
    By Thomas19804711 in forum Mach Mill
    Last Post: 01-20-2022, 11:32 PM
  3. Replies: 1
    Last Post: 03-18-2020, 06:02 PM
  4. help dimensions of hitorque x2 dimensions?
    By Winterwatchers in forum Benchtop Machines
    Last Post: 04-17-2014, 03:35 PM
  5. Help with dimensions
    By native34 in forum Benchtop Machines
    Last Post: 06-19-2013, 02:37 AM
