586,796 active members*
2,576 visitors online*
Results 1 to 8 of 8
    Apr 2011
    131
    ID this ISO20 toolholder
    Can anyone ID this style of ISO20 toolholder.
    The tool is 1/8" secured by a set screw.
    All I can find in my searching is a version that takes a collet.
    Dec 2008
    3113
    Re: ID this ISO20 toolholder
    "Side lock" tool holder
    - this style is not suitable for high RPM cutting machines as they (by design) are out-of-balance
    Personally... I would not run these above S8000 as vibrations are a major cause of bearing failure.
    Jan 2013
    474
    Quote Originally Posted by crazybrit View Post
    Looks like an SK20
    Apr 2011
    131
    Quote Originally Posted by Superman View Post
    a) where can one find a "side lock" ISO 20 holder?
    b) The spindle on this machine is 5000rpm max.
    Apr 2011
    131
    Quote Originally Posted by servtech View Post
    Looks like an SK20
    It's an ISO20. Can you be more precise? Like a URL to something similar to what is pictured. Thanks!
    Dec 2008
    3113
    Slow down....
    Does your machine take ISO20 or SK20 ?
    Or even BT20 or CAT20
    Does it have a tool changer ?
    It is important to get the right holder form & pull studs
    You may have some mention in the machine / spindle specifications.
    If you manually change tools, then it may not matter, but sidelocks have tendered to fall from favour due to higher spindle speeds & balance needs of newer machines.
    Collets (ER16, range 1-10mm) run truer than sidelocks & drill chucks
    Apr 2011
    131
    It takes ISO20. Which is why I said "Can anyone ID this style of ISO20 toolholder" rather than "can anyone ID this style of SK20".
    What is pictured is one of the ISO20 toolholders from the machine.
    So it's an ISO20. It's not something else :-)
    As I already mentioned the machine has a 5000rpm spindle.
    In case it's not clear, I was asking if anyone knows of a supplier of this side-lock style ISO20. I'm aware of issues with varying pull studs but it doesn't change the question above.
    Dec 2008
    3113
    Sorry, my question was a bit vague
    If your machine does not have a toolchanger, and you manually change your tools.
    Then... ISO20 holders may not be necessary, as long as the taper & drive slots match to the spindle drive, you would need to compare the parts/drawings.
    I also am finding only ER holders, & shell endmill holders on the Web.
  1. fretting in ISO20 spindle taper
    By cncfun1 in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2022, 03:29 AM
  2. Let's build some ISO20 spindles
    By Azalin in forum Vertical Mill, Lathe Project Log
    Last Post: 12-08-2020, 08:19 PM
  3. ISO20 or ISO30 Headstock For Sherline
    By superchargerjim in forum Benchtop Machines
    Last Post: 08-19-2019, 07:20 PM
  4. ISO20 or ISO30 Headstock For Taig
    By superchargerjim in forum Taig Mills / Lathes
    Last Post: 01-03-2019, 09:12 PM
  5. iso20 vs TTS
    By spacehitchhiker42 in forum Benchtop Machines
    Last Post: 08-25-2018, 05:27 AM
