587,040 active members*
2,873 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Maestro CNC engraving for SCM Accord 25 fx
Results 1 to 5 of 5
    Dec 2022
    8
    Hi, I want to engrave text on the piece and I need it in the Times New Roman font. When I apply the engraving machining to the geometry, it mills out the entire letter. E.g. I use the letter "P", or anything with a boundary in the letter it mills out the boundary. How do I avoid this?
    Jun 2005
    1730
    Re: Maestro CNC engraving for SCM Accord 25 fx
    Get some single line fonts. You can find them for free online.
    Dec 2022
    8
    Yeah I thought so, Maestro does have a few already on there. I need to find a good one because my bosses want engraving with the Times New Roman font.
    Dec 2008
    4548
    Quote Originally Posted by Joel2001 View Post
    I reverse engineered fonts to single line by vcarvimg the font to create a single, centerline toolpath, then using gcode2dxf (found on this forum) to turn the toolpath to dxf entities. I can then “flatten” the dxf to make it planar. Presto! Stick font from any font.
    Depending on your needs, you may have to clean up the little ears made from vcarve to leave only the centerline. Then agaian too, if you can vcarve, you kindof already have what you are looking for. I think i did this for someome who didnt have vcarving or something…
    Dec 2022
    8
    Quote Originally Posted by BurrMan View Post
    That is a good idea! I will look in to that in the future. I managed to get the engraving to work properly now. Our tool was not set up correctly to begin with (conical mill set up as a straight cutter). If you highlight the letter with the boundaries to apply the machining, it will machine around that boundary to produce the engraving.
