586,975 active members*
3,022 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Hard disk problem - osp-u100m
    Dec 2022
    4
    Hello everyone
    i have osp-u100m machine and suddenly i got error msg:
    5427 DNC-DT Program select error 80000099 and when I checked the control I found a noise coming from the hard disk case and the LED turned into red and buzz started to make noise
    does anyone know the solution for this problem ?
    Aug 2011
    420
    Re: Hard disk problem - osp-u100m
    is this harddisk 3.5" ide?
    "Imagination is more important than knowledge."
    Jun 2005
    8
    Quote Originally Posted by saeedmohamed View Post
    Hello everyone
    HDD may have a bad block or worn out bearings. so if possible turn and run the HDD upside down to use top bearings, until you get the HDD replaced
    Dec 2022
    4
    Quote Originally Posted by reuelt View Post
    Thanks for replying can you explain to me how can i do it? because now I can only get one LED on and the other turn on for a few seconds and turned off again as shown in the pic. i did a test over my computer by connecting HDD and it look fine and working
    one more hint, I got other HDDs but the machine cant detect them is it a reason for initialization?
    Attached Thumbnails Attached Thumbnails 319162462_537808021725795_2703473632986492927_n.jpg
    Dec 2022
    4
    Quote Originally Posted by kurmay View Post
    Similar to the one in the attached picture. but i have RAID Drive 1 and Drive 2 total around 5 or 4 GB
