586,551 active members*
3,213 visitors online*
IndustryArena Forum > Manufacturing Processes > Chucking and Measuring > Probing on a CNC Mill using Flat Star or Right Angle Probe
    Nov 2016
    19
    Has anyone figured out how to use a Flat Star or Right Angle Probe on a CNC Mill using GoProbe or other Renishaw probing routines?
    Our fixtures hold parts with bores in the Y-Axis on the Horizontals that we need to align XYZ Zero to.
    The way they do it now is to slide a gage pin inside the bore and probe it as a half circle in the X-Z Axis, then remove the Gage Pin before machining.
    Problem is, this is time consuming and sometimes the pins get stuck and take longer than the part run time to get unstuck, and other times they don't remove all of the Gage Pins and break off tools.
    A simple solution would be to do like the Inspection Department does on the CMM and use a Star Probe, but the Productivity+ and GoProbe routines look to be written to probe using straight "Down-Z" Probes only.
    So... before I tackle this as a project and learn to create new custom O9xxx programs to do this, I thought to ask if this "Wheel" has already been "Invented"
    Nov 2016
    19
    Re: Probing on a CNC Mill using Flat Star or Right Angle Probe
    Just in case anyone else is interested in X-Z Diameter Probing using a Renishaw Probe:
    Renishaw got back to me and said it is available.....but only for Fanuc and similar controls like Haas, NOT on an Okuma.
    I wish Okuma had a "Fanuc Compatibility" Mode...
  1. Probing program for renishaw probe
    By Uhrenholt in forum Fanuc
    Last Post: 03-13-2019, 11:17 PM
  2. Star SR20 front drilling head with adjustable angle
    By rpdayton in forum CNC Swiss Screw Machines
    Last Post: 09-09-2016, 04:46 PM
  3. CNC made aluminum angle, flat bar and square tube.
    By Tonytool in forum USA Club House
    Last Post: 07-22-2016, 04:45 AM
  4. how to mill angle iron flat on all sides.
    By matridium in forum MetalWork Discussion
    Last Post: 04-01-2016, 08:16 PM
  5. angle iron & flat bar comb tool
    By anil in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-29-2007, 07:13 AM
