586,801 active members*
4,523 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Strange behavior from handwheel in version 18-11-22
Results 1 to 10 of 10
    Apr 2022
    12
    Since the version 18/11/22 I and a few friends have the
    problem that the radio handwheel no longer works as accurately as before when moving the axes.
    The movement no longer stops immediately.
    The axes still seem to run a little after.
    First I searched the error with me but the problem have several people.
    Could someone from Planet-cnc check this?
    Thanks a lot
    Mar 2017
    1322
    Re: Strange behavior from handwheel in version 18-11-22
    Perhaps because of "Round" setting?
    I need more information. Which mode and how it is used?
    I also need zip file of your profile and video showing this problem. You can send this to our email.
    Apr 2022
    12
    I will check the settings for the handwheel again.
    It could be that the selection to the step is no longer selected.
    Unfortunately, I can't do that until early next week.
    Apr 2022
    12
    I have noticed that you and ScorpionTDL have searched for the error over the weekend.
    Thanks a lot
    Aug 2011
    999
    I noticed such extremely slow deceleration in previous versions, but I guess with latest update it got worse. Kind of got used to it but having the machine stop immediately when the handwheel stops would be nice.
    Right now, it overshoots at high speed setting sometimes a centimeter or two.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Aug 2020
    133
    the latest version 2022-12-11 fixed the issue for me
    Jan 2013
    474
    Problem is, in some cases if handwheel is rotated quickly the pulses are stored / buffered so even when you stop turning the handwheel, the axis will continue until the buffer = 0 pulses. Handwheel pulses need matching with the controller.
    Mar 2017
    1322
    When you stop turning the wheel, machine must decelerate to stop and should not stop immediately, otherwise something might break or steps are lost.
    Jan 2013
    474
    Quote Originally Posted by PlanetCNC View Post
    I agree, however it would depend on whether you are closed or open loop. Closed loop usually stop much quicker because they more accurately follow pulses.
    Mar 2017
    1322
    If machine is able to stop sooner then machine deceleration settings can be set higher.
    There was an issue with averaging logarithm and deceleration took longer than expected. This is all fixed now.
  1. Strange KmotionCNC behavior
    By CNCMAN172 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-08-2017, 02:14 AM
  2. Strange behavior with VFD
    By BanduraMaker in forum Gecko Drives
    Last Post: 11-15-2011, 03:00 PM
  3. Upgraded to latest version, y axis strange behavior
    By DirtBound in forum Machines running Mach Software
    Last Post: 11-06-2011, 02:14 AM
  4. Strange Behavior.
    By riveracnc in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2008, 01:54 AM
