587,056 active members*
3,546 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Need diagnostic help! MC V U10M. MCS alarm tool change
    Mar 2020
    4
    Issue:
    MCS alarm occurs During tool change. Machine will do several tool changes, sometimes 5, sometimes 10. Then it stops with a MCS alarm on the MG axis(tool change motor).
    Condition:
    Not always same tool, but always same spot. When it removes the tool from the spindle, tool goes down, arm starts to rotate, but only rotates about 1 inch (25mm).
    Efforts so far:
    Megged motor and cable
    Swapped drive
    Set all the tools in magazine to Heavy Tool, it hasn’t failed failed since we did this, but it was late in the day so, we only did a few tool changes. We plan on doing more tomorrow.
    Trying to fix it without rebuilding the gearbox. That’s a big job and I don’t want to tear into that until I’m positive the gearbox is the culprit.
    All questions are welcome, ideas are preferred!
    Thanks everyone.
    Mar 2020
    4
    Quote Originally Posted by ibrockin View Post
    Issue:
    Condition:
    Efforts so far:
    Swapped drive
    Thanks everyone.
    Update: setting all the tools to “heavy tool” and made over 150 tool changes with no alarm.
    Apr 2009
    1262
    Re: Need diagnostic help! MC V U10M. MCS alarm tool change
    That motor I believe is used for both driving the tool change arm and the magazine rotation and switches by mechanisms between devices. It is not uncommon to have the switching position get out of alignment and then not want to engage properly. I would try adjusting the engagement orientation parameter slightly to see if it makes the problem go away without losing the speed.
    You may be able to get that procedure through your distributor service group. I don’t have it here, but additional info may also be in your maintenance manual.
    Best regards,
    Experience is what you get just after you needed it.
    Oct 2009
    119
    Try to slow ATC change speed. Speed is dangerous
  1. Macturn MCS alarm
    By Green Button in forum Okuma
    Last Post: 09-13-2021, 02:11 PM
  2. Replies: 1
    Last Post: 10-15-2019, 01:08 PM
  3. G111 tool change macro Okuma u10m controller
    By schwinn83 in forum Okuma
    Last Post: 02-25-2014, 02:26 AM
  4. Replies: 4
    Last Post: 02-18-2014, 12:10 AM
  5. RhinoCam does not code MCS change
    By AussiHorologist in forum Rhinocam
    Last Post: 04-03-2012, 01:01 PM
