587,030 active members*
3,626 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Way lube pressure switch
    Nov 2004
    24
    I'm trying to run down an MTB 20 alarm (lube pressure switch) on my Tree J-250. I had this before and it seemed to go away after I reset the K10 relay. I'm thinking my pressure switch is bad and wondering if anyone has a reference on a replacement? This mill has a Vogel lube pump installed. The pump seems to run on and on until it errors out with the MTB 20 alarm. A reset merely fires the pump right back up until it alarms again. I did measure 24v on one pin of the pressure switch so I know it's getting voltage. I shorted across to the other pin on the pressure switch and the pump continued to run which I thought was odd. Would think closing the switch would have stopped the pump? I'm thinking the pressure switch is shorted out but not entirely sure. I know the pump is working because I’m getting plenty of lube on the ways.
    Thanks for any input you can provide.
    Dan Henderson
    Oct 2006
    60
    Re: Way lube pressure switch
    Shoot me a direct email [email protected]. For some reading I can’t get the PMs to work
    Nov 2004
    24
    Email sent. Thanks
  1. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  2. Replies: 3
    Last Post: 03-04-2012, 10:42 PM
  3. EZ Path II Lube Pressure Switch Fault
    By speedracer50 in forum Bridgeport / Romi Lathes
    Last Post: 01-17-2012, 06:00 AM
  4. Haas lube pressure?
    By UBRacing in forum Haas Mills
    Last Post: 10-28-2010, 02:04 AM
  5. LB15 way lube pump pressure
    By rev4q in forum Okuma
    Last Post: 07-06-2010, 02:56 AM
