586,546 active members*
3,260 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Journeyman Y Axis noise/vibration
    Nov 2004
    24
    I have a J-250 mill which has developed rough movement in the y axis. I’m getting vibration and rough movement while jogging at medium speed. Occasional, it throws a y axis servo error. I first assumed it was caused by mechanical binding of the gib and or lack of lubrication. I’ve since tested and ruled this out since I could manually move the axis back and forth using a power drill on the ball nut and found it smooth as glass. I checked the brushes in the Balder servo motors and found they were all fine. Any thoughts on what is causing this rough movement? Do I need to adjust pots on the servo drive? Thanks for any insight.
    Dan
    Nov 2004
    24
    Re: Journeyman Y Axis noise/vibration
    Update: I was able to resolve my issue with the Y axis. The mill had sat unused for several months before firing it up this time. I cycled the lube pump multiple times and jogged the axis back and forth for several minutes which has eliminated the vibration. I’m going to chalk this issue up as a case of stick slip on the ways.
  1. Journeyman 250 X axis noise
    By LuvToFish in forum Tree
    Last Post: 03-15-2022, 03:49 PM
  2. 4th axis binding or vibration noise with video!
    By s2jesse in forum Tormach Personal CNC Mill
    Last Post: 01-26-2017, 06:52 AM
  3. noise and vibration
    By mofosheee in forum Tormach Personal CNC Mill
    Last Post: 02-03-2015, 10:55 PM
  4. Need Help. Spindle noise and vibration.
    By wolfman1 in forum Fanuc
    Last Post: 07-29-2013, 09:01 PM
  5. Noise/Vibration on Z-Axis?
    By adt2 in forum DIY CNC Router Table Machines
    Last Post: 12-30-2011, 12:59 AM
