586,626 active members*
2,446 visitors online*
Results 1 to 6 of 6
    Jun 2016
    57
    0T control input
    On a 0T control, how can the letter "E" be input from the keypad? Secret key sequence? We can upload/download and edit on a pc, but cannot use the machine keypad to do this.
    Re: 0T control input
    If you have the small basic keypad like many O models do, there is no E and there is no secret sauce to get one. Basically SOL.
    Dec 2009
    964
    you can try to flip the parameter 38 bit 3 from a standar key pad to a full key pad and see if yoiu get the E letter on
    FLKY
    1-CRT/MDI uses a full key
    0-MDI/CRT uses a standard key
    Quote Originally Posted by zavateandu View Post
    FLKY
    This I got to see. Would be great.
    Just checked an OM book and 38.3 was blank. Have to dig further.
    Quote Originally Posted by the_gentlegiant View Post
    0038#3
    FLKY With the CRT or MDI, a standard keypad is used/full keypad is used.
    So what you guys are saying is... even if my physical keypad is the small, basic type, if I turn on full keypad with 38.3, I'll then find a FLKY soft key on my monitor that would bring me to a full keypad graphic or UI??
  1. Converting an Anilam Crusader M to a PC control - need input
    By mtechserv in forum Controller & Computer Solutions
    Last Post: 05-10-2014, 03:27 AM
  2. Retrofit CNC control, input appreciated!
    By Smokio in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2013, 02:40 PM
  3. VFD input speed control
    By LUCKY13 in forum Phase Converters
    Last Post: 01-28-2009, 09:55 AM
  4. PC input/control with Fanuc 5
    By jevs in forum Fanuc
    Last Post: 10-22-2008, 03:49 AM
  5. Need input for servo control systems
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-31-2005, 05:45 PM
