586,903 active members*
2,671 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Tool for milling V groove
    Jun 2022
    30
    Hello guys,
    can someone recommend me some tool for ER20 for milling V groove into aluminium 5083.
    I need to mill deeper 120° in few passes and do not want to flip material in angle.
    I have only chamfer, I assume that it is not ideal tool for it, I would appreciate any picture what should I look for...
    thank you
    Dec 2008
    3117
    Re: Tool for milling V groove
    What angle of vee ?
    Can you put the part at an angle, and use a standard tool ?
    ... ie set at 45° and use an end mill for a 90° vee.
    ... same idea but use a dovetail cutter for 30° or 60°.
    ... use a taper tool, made to the required vee angle. Problem with this is the point goes to 0°, so feeds will be slow, ie about 0.001/rev
    Rough pic would be nice
    Mar 2004
    1543
    They sell mill drills with this point angle, feed would be VERY slow, but no need to re fixture
    Jun 2022
    30
    Thanks for advices.
    Its just flat material and need V groove 120° without rotating on vice.
    Drill mill suits my needs, but what I have found, that these drill mills
    are all made in USA ? They are little bit pricy. Cannot find some seller in Europe...
    Does anyone know some seller in Europe ?
    Nov 2022
    If you have quantity in total needs, we can supply . First free samples, second official orders.http://zjkxptools.en.alibaba.com , find me and I want to find real customers
  1. milling thread like groove on the cylinder - how
    By Marecki_l in forum Mastercam
    Last Post: 10-04-2017, 12:26 PM
  2. Milling an Oring Groove
    By mark029 in forum GibbsCAM
    Last Post: 03-20-2016, 09:09 PM
  3. V-Groove Milling issue
    By CYoung in forum BobCad-Cam
    Last Post: 10-24-2014, 01:15 AM
  4. MILLING GROOVE IN 1045 STEEL WITH TINY TOOL
    By NIRAV1OO7 in forum G-Code Programing
    Last Post: 04-12-2014, 01:48 AM
  5. MILLING GROOVE IN 1045 STEEL WITH TINY TOOL
    Last Post: 04-11-2014, 01:13 PM
