587,161 active members*
3,223 visitors online*
Results 1 to 11 of 11
    Mar 2004
    37
    1mm endmills/bits
    i realize a topic such as this is probably already posted but in my searches I have hit nothing but blanks... Please forgive me if I have overlooked any of the forums....
    I am looking for a source on 1mm bits for cutting Acrylics or other plastics...
    I have looked up MSC and a few other spots but nothing is coming up that will work...
    I will try anything at this point... just looking for some direction...
    Jun 2006
    629
    Try endmills that are designed for aluminum. They are sharp enough to cut the material and not hammer it out.
    Robb Jack makes endmills that small. I can't remember off had if you can get the Garr 242M series that small
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    746
    Check out the carbide burrs that are used in the dental profession. The only thing is that they are 1/16" shank diameter. The oral surgery burrs are a bit longer in length. Here are a couple of suppliers.
    http://www.sswhiteburs.com/carbide_burs_guide.php
    http://www.microcopydental.com/neoburr.html
    Or search Carbide Dental Burrs.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Jun 2006
    629
    sorry double post(nuts)
    Jun 2006
    629
    I'd be hesitant to try Burrs for cutting plastic, you need room for the chips to get out. Stick with 2 flute endmills and your material bill will thank me!
    746
    I agree, Acrylic is some soft stuff. The only reason I posted it was that they are small. The harder the plastic, the better the chip removal.
    Sep 2007
    31
    Jul 2004
    374
    www.harveytool.com
    VERY nice tools. I use quite a few of their endmills 0.030" to 0.050", stub length, 2 flute in aluminum.
    Jul 2007
    195
    If your working in a wood shop you use "bits"
    If your working in a machine shop you use endmills or cutters.
    There I got that off my chest..........lol
    I cut alot of plastic in my shop and we use high helix three flute carbide endmills whenever possible. Your main problem is heat. If you let the chips stick to the cutter you will end up with a junk part and a broken tool. You would be suprised how much cutting fluid makes a differance when cutting plastic.
    Be carefull what you wish for, you might get it.
    Jul 2007
    195
    We use alot of Garr brand cutters and sometimes Micrograin carbide.
    Any good tool supply house should be able to set you up with any number of good quailty carbide cutters. Believe it or not the softer the plastic is the more trouble you will have trying to cut it. Soft plastic will squish out of the way and spring back and closeup the cut if you don't use very sharp cutters.
    A word to the wise.............
    Jun 2007
    3734
    Smile PCB drills are small. Nice rout
    Quote Originally Posted by johnm99 View Post
    Go to your friendly PCB manufacturer and get some worn out cutters/drills
    Carbide will last much better. HSS in plastics get dulled very quickly.
    What is worn out for fiberglass pcbs is still pretty good.
    Router bits are very good also. PCBs wear them out too.
    New Ones...
    look here. Search google for PCB drills. A fwe links..
    http://www.uniontool.co.jp/english/product_01.html
    http://www.northbaytechnical.com/standard1.htm
    http://www.megauk.com/carbide_drill_bits.php
  1. Endmills okay for wood?
    By phantomcow2 in forum DIY CNC Router Table Machines
    Last Post: 09-02-2010, 02:55 PM
  2. Coolant Fed Endmills
    By eorourke in forum MetalWork Discussion
    Last Post: 06-22-2007, 03:35 AM
  3. Sharpening Endmills
    By ADCORGUY in forum Toolgrinding / Toolgrinding Machines
    Last Post: 03-30-2007, 01:55 PM
  4. Working with Endmills
    By Burn in forum Benchtop Machines
    Last Post: 05-16-2006, 08:40 PM
  5. Anyone used these endmills?
    By Cold Fusion in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2004, 05:16 AM
