586,610 active members*
3,652 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Colchester Storm A90 Jog mode stops spindle.
Results 1 to 5 of 5
    May 2006
    14
    I have a Colchester Storm A90 with the Fanuc 21i-t control. It also has the simple control panel as shown in the picture.
    Here is the sequence of events....
    CUSTOM GRAPH --> MDI
    MDI: G97S500M3;
    CUSTOM GRAPH --> MANUAL
    JOG
    Spindle stops. Not particularly useful, to me at least. Is there a parameter or option that can be enabled to make the spindle stay on so I can face a piece of stock using the jog mode? Or turn a simple diameter without having to use the hand wheel?
    Dec 2009
    964
    Re: Colchester Storm A90 Jog mode stops spindle.
    As far as ia know you can input the spindle speed in MDI but in jog mode you need to start and stop the spindle by push buttons
    It is normal to stop the spindle when switch the modes .it is just waiting to push the spindle foward or reverse and increase or decrease the spindle speed by override
    May 2006
    14
    zavateandu, you are correct in the normal operation. However, since I have the stripped down control panel I don't have spindle start/stop button(s). I was curious if there was an alternate way to do the same thing. If not, then I'll continue as I have, but I would love to figure something out.
    May 2016
    526
    When you select jog on any Colchester the spindle stops.
    It's written in the ladder so there is no way using parameters
    Post your ladder file
  1. Colchester Tornado A90 alarm 1012 Turret not moved
    By lootspastille in forum Colchester Tornado lathes
    Last Post: 06-27-2021, 10:55 PM
  2. Cross drilling on Colchester A90
    By Clive Dunn in forum Colchester Tornado lathes
    Last Post: 03-04-2014, 03:33 PM
  3. Alarm 300 APC on Colchester Storm A-50 Fanuc 21i-T
    By Nastyzen in forum Colchester Tornado lathes
    Last Post: 06-26-2013, 10:35 PM
  4. Clausing Colchester Storm CNC 100
    By CNC BOSS in forum Colchester Tornado lathes
    Last Post: 06-02-2012, 04:39 AM
  5. Hardinge Conquest T-42 spindle will not rotate in jog mode
    By DannyP in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2011, 05:01 PM
