586,570 active members*
3,767 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Co2 laser problem, electrical discharge sound, too much power.
    Jul 2021
    4
    Hey. I hope this is the right section.
    I bought a second "red and black" 130w co2 laser. First one is running fine, all good.
    The second one - At some times I hear electric cracking noise, discharge somewhere near tube.
    The first machine does perfectly engrave at 150mm/s and 9% power (mat finish, perfect).
    The second machine even on 500mm/s and 9% power does engrave at least 0.5mm deep.
    Both machines are supposed to be identical..
    Any suggestions appreciated. Thank you in advance.
    Jul 2021
    4
    Re: Co2 laser problem, electrical discharge sound, too much power.
    Update: So, cracking noise gone by itself and there is a little switch on tube PSU which enables power control.
