586,659 active members*
3,656 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Problem with Face Operation in Conversational
    I'm a newbie with a 770M. As pictured I'm setting up a facing op where the origin of the material is on the back, left most corner, Z is the top surface. However the gcode generated has the tool moving to X 13.2875, Y -0.7750 (line 41 of the code) before making the first pass in the wrong direction as shown in the conversation screen. Is my setup wrong?
    Is there a way to post gcode in a better way than as a txt file?
    Apr 2013
    1788
    Re: Problem with Face Operation in Conversational
    The first move just goes to a start position off the part. Notice that Z=0.6 above your stock. If you look slightly further down the Gcode you see:
    (Pass 1)
    F 4.0 (Z Feed, inches/minute)
    G1 Z -0.3985
    F 12.0 (Feed, inches/minute)
    G1 X -0.0375 Y -0.7750
    where the tool actually begins to cut at 0.3985 below the top of your stock. BTW, are you certain that a 0.4 inch DoC is appropriate?
    Thanks for the reply!
    I see what your saying but it's not what I see going on with the mill. I try to get some video of the actual path. I'm machining some shorts of TREX, a composite plastic wood decking - something that is less likely to cause damage during a crash.
    Jan 2016
    99
    Did you try using spiral instead of rectangular. This has always started in top left corner for me. This will climb mill all around the part and reduce any burring to a minimum.
    Isn't Trex a little gummy to mill, I never tried milling it but have cut on saws.
    Dave
  1. failure during operation of PP conversational code
    By Fenichel in forum Tormach PathPilot™
    Last Post: 04-06-2020, 10:33 PM
  2. why can't i rotate tool angle in turning face operation?
    By cryptopsy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-19-2018, 07:13 AM
  3. Face milling operation on Table type Horizontal Boring Machine
    By SatishNaik in forum News Announcements
    Last Post: 09-05-2013, 07:44 AM
  4. Which operation for a curved face/surface?
    By Zeppelin1007 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-05-2013, 01:57 AM
  5. Face or pocket, which operation?
    By jaras in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-13-2012, 06:50 AM
