586,991 active members*
3,923 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan S310 home position problem
    Jun 2010
    23
    We have a Doosan S310 with a Fanuc Oi-Mate T control which has recently started to default to a Z axis value of +500mm when you send it home this is a problem as it only has 380mm of Z Axis movement.
    Does any one know the parameter number for the Z Axis home position.
    Feb 2013
    788
    Quote Originally Posted by brit61 View Post
    Incremental position coder type
    1850 grid shift tunes the location from dog to a potential 4096+ or 4096- and 1240 is what that selected position is going to be called.
    Absolute position coder could do that with a larger grid and the right procedure, or a procedure change could toggle 1815.4 at the desired HOME position, and again, use 1240 to name it.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jun 2010
    23
    Re: Doosan S310 home position problem
    Hi Darryl,
    Thanks for the help I was not fully understanding the work shift function as it is a new machine to me but it is sorted now!
    Best regards
    Alan
  1. Internal BMT toolholders to suit Doosan S310
    By brit61 in forum Daewoo/Doosan
    Last Post: 03-19-2021, 03:49 PM
  2. HELP DOOSAN S310 SM Fanuc 18T
    By nikniknik in forum Daewoo/Doosan
    Last Post: 02-11-2020, 03:54 PM
  3. HELP DOOSAN S310 SM Fanuc 18T
    By nikniknik in forum Turning
    Last Post: 01-27-2020, 12:19 PM
  4. 6M Home position problem
    By Richard Horton in forum Fanuc
    Last Post: 07-13-2010, 02:33 PM
  5. Doosan Tailstock home position problem
    By secretsquirel in forum Daewoo/Doosan
    Last Post: 01-17-2010, 07:12 PM
