586,745 active members*
6,663 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMU50 Traori Singularity Minus B movement
Results 1 to 1 of 1
    Aug 2022
    Question DMU50 Traori Singularity Minus B movement
    Our DMU50 allows for -5 degree's in the B rotary axis.
    When I program a 5-Axis toolpath to utilize(up to) -5 degrees, the table rotates around 180, and doesn't go minus. The B will always stay positive, even though the program shows minus B numbers.
    I assume this is TRAORI transforming minus B values to C rotary motion.
    Is TRAORI(2) what I need? I don't understand how TRAORI Is different than TRAORI(2).
    Or, could this be a soft limit in the control somewhere?
