586,516 active members*
3,854 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > SyiL X4 + (Plus Manual Needed)
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Oct 2014
    28
    re: SyiL X4 + (Plus Manual Needed)
    I did a break-in procedure for the spindle bearings. I started at the lowest speed I could get (about 200 rpm) for 10 minutes in each direction then doubled the speed in each direction for 5 minutes each until I reached the max RPM (about 75 minutes total). It is a lot quieter and sounds more appropriate for a belt drive machine. At the end of the procedure, the spindle was warm to the touch but not too hot. I am happy with the results.
    Now I just need to iron out the Z Axis limit switch issue.
    neilw20 - thanks again for all your help.
  2. #22
    Jun 2007
    3757
    Quote Originally Posted by mlchman View Post
    Ok. I watch this space.
  3. #23
    Re: SyiL X4 + (Plus Manual Needed)
    HI all i am also rebuilding a syil x4 plus but mine has a vfd and a larger motor and not the servo motor that the manual has
    could i have a copy of the syil x4 plus xml file also please
    i have been messing with mach3 to get my machine setup and i have the axis moving and the limit switches but no control over the spindle or the coolant ( all work fine in manual mode)
    I was able to find a copy of both the x4 and x4 plus manual but neither seems to cover the head ? motor setup of my machine.
    thanks for reading
  4. #24
    Oct 2014
    28
    Sorry it has taken so long to get back with you.
    I would be happy to provide a copy of the XML file Syil of America sent to me - if I knew how to post files.
    Okay, I think I found it - I zipped the file and it seems to be there. Let me know if it works for you.
    mlchman
Page 2 of 2 12
  1. Syil S5 manual
    By kamros in forum Syil Products
    Last Post: 03-04-2013, 03:30 PM
  2. Syil Manual Mills?
    By magma-joe in forum Syil Products
    Last Post: 02-20-2012, 02:14 AM
  3. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  4. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  5. SyiL Present X4 Manual Machine
    By syil in forum Syil Products
    Last Post: 07-13-2008, 06:26 AM
