586,533 active members*
2,997 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Suggestions when cutting 20 Gage CR Sheet
Results 1 to 1 of 1
    I have been using my Torchmate Plasma Table/Hypertherm 65 for thicker material building car frames, brackets, etc. Just started using it for art projects, 20 gage cold rolled. I see folks here with crisp cuts on thin metal, trying to get there. Basic settings are .1 delay, .06 torch height, 128 V (sample on), AVHC on, tool width set at .060, lead in .125 90 degrees. Material is 4 inch square. Model A grill is about 3 foot, cut at 45 amps 400 ipm, note divots at lead in and poor corner cuts, so I drew a part and ran trials. Here are the details of the trials, trial number, Amps, Speed.
    1, 35, 400
    2, 30, 400 Didn't cut through
    3, 35, 450
    4, 35, 350
    5, 30, 350
    6, 30, 300
    7, 30, 250
    Biggest issues are the small holes aren't round, probably due to lead ins, and the bottoms of the V's aren't sharp. Any tips or recommendations would be appreciated.
    Attached Thumbnails Attached Thumbnails IMG_5983 small.jpg   IMG_5984 small.jpg
  1. Al 3003 sheet metal milling suggestions?
    By philba in forum Milling
    Last Post: 11-20-2019, 05:55 PM
  2. Replies: 1
    Last Post: 11-08-2019, 04:40 PM
  3. Replies: 0
    Last Post: 12-27-2013, 02:38 AM
  4. suggestions for cutting .015 flashing aluminum sheet
    By greenene in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-12-2012, 08:21 AM
  5. First Mill Suggestions - mostly Stainless Sheet
    By SPyKERMods in forum Benchtop Machines
    Last Post: 11-28-2012, 02:07 AM
