586,898 active members*
2,845 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Convert a .STP file to DXF format
Results 1 to 4 of 4
    Feb 2005
    117
    I am receiving a lot of drawings in STP format. The cad program I prefer to use is Auotcad Lt. which
    does not support STP.
    It only supports DXF and DWG
    I am getting a Solidworks seat which will handle the conversion but will not be up to working with it for a while.
    Any suggestion for a quick solution for converting STP to DXF or DWG format?
    Thank you
    Apr 2014
    8
    Re: Convert a .STP file to DXF format
    HI,
    You could try the free version of Fusion360. I know this can import STP as a mesh and has some sort of DXP export function. If you upload a sample, I could try for you if I get 5.
    Apr 2003
    1357
    Download the Rhino demo. You will have 90 days to use it for free. Rhino is very good at file translation. Import your STP file and save it as DXF or DWG.
    Jun 2015
    4156
    hy john, are those 2d or 3d objects ? if 2d, can you share a few stp files, so i'll try to convert them / kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
  1. Need to convert dxf to 3d file
    By Taleismin in forum Uncategorised CAD Discussion
    Last Post: 06-26-2014, 04:49 AM
  2. convert cimitron file to iges or stp
    By earlene in forum Uncategorised CAM Discussion
    Last Post: 07-31-2012, 04:41 PM
  3. Convert Corel CDR file to IGES, 3DM, or STP
    By easom in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-11-2010, 04:30 AM
  4. convert smartcam to dxf format?
    By imfool in forum Uncategorised CAM Discussion
    Last Post: 03-24-2004, 04:15 AM
