Hello.
I've got KL5056 drivers and a KL5042 driver.
When using the KL5056, the motor rotates one way only.
When I switch off the system and I unplug the green conectors from the KL5056 and I plug a KL5042 on its place, (so the wiring are the same), the motor rotates fine in both directions once switched on the system again.
I've tested different current and microstep settings with the same results. I've tested bipolar series and bipolar parallel wirings too.
There is no way to get the motor rotating two ways when using the KL5056drivers.
Can anybody suggest any help?.
Thank you.
