586,655 active members*
2,367 visitors online*
    Jan 2015
    9
    MACH3 MachTurn not picking up "Index" on mini lathe
    I recently purchased a Harbor Freight Mini Lathe that someone converted and I am wanting to get a spindle index/tach set up to cut threads, etc.
    It is using Mach3 with a Gecko 540 running through a UCC100.
    I purchased a C3 Index pulse card and wired it in according to the diagram in the description. It has its own 5v power supply. When I turn the spindle, the LED on the card blinks properly. But I can't get it to pick up the index in Mach Turn. I have the output on the card wired to the #1 pin on the Gecko. I have made the Index active in MachTurn on Port 1 Pin 10 (diagram indicates that Pin 1 on Gecko is Pin 10) but when I go to the diagnostic page and roll the spindle around the "Index" light doesn't light up.
    Would anyone have any input on what I may be overlooking?
    Thank you in advance
    Jan 2018
    1516
    Quote Originally Posted by cdowns View Post
    Is there an actual sensor on the Spindle for the card to read?.
    Jan 2015
    9
    Re: MACH3 MachTurn not picking up "Index" on mini lathe
    Yes, put an index pulse card with slotted disc for pick up, I have just found out that UC100 doesn't support Index in Mach 3 turn. Looking into a wire around for that now. Any ideas?
    Sep 2005
    1195
    wait for uccnc turn software released ...
  1. Replies: 3
    Last Post: 06-25-2014, 03:51 PM
  2. Want to buy Harbor Freight Mini Lathe 4"x5"
    By WinstonLathe in forum Want To Buy...Need help!
    Last Post: 04-28-2012, 03:12 AM
  3. Hitachi HT 20 CNC Lathe "turret index time over alarm" after battery change
    By surfit in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 04:35 PM
  4. Disabled "Lathe Index" command
    By vadim_m in forum EdgeCam
    Last Post: 02-19-2009, 12:23 PM
  5. Homier 7"x12" CNC Mini Lathe on Ebay
    By whiteriver in forum Mini Lathe
    Last Post: 04-16-2007, 12:33 AM
