586,957 active members*
2,915 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Stepcraft > How to quickly check the distance between cuts in DXF files?
    May 2022
    4
    Hello,
    Please tell me which program can quickly check the DXF files to find out the minimum distance between objects in the drawings.
    For example, for cutting metal 3 mm, set a minimum distance of 3 mm and highlight all the lines in the drawing that are close to each other and the plasma can burn the metal.
    There are a lot of files. I want to be sure that I will cut, because the metal is expensive.
    Jun 2015
    4156
    Re: How to quickly check the distance between cuts in DXF files?
    hy :) i can create a program, that will check all your files, make adjustemtns, etc ... customized as you wish / kindly :)
    Jun 2015
    4156
    hi :) if you wish, share dxf files, and i will identify clearances between shapes
    i allready do this, scaning many files at once, generating reports, in file pin-point of hot zones, generating g-code based on them, etc / kindly :)
    May 2022
    4
    Nice!! Thanks for link. I found out some useful for me.
    Jun 2015
    4156
    what link ?
