586,501 active members*
2,556 visitors online*
Thread: fusion360
Results 1 to 16 of 16
    fusion360
    Hello Fusion360 just updated 25/05/2022
    now i can't engrave offset curves here is a photo. Thank you
    Apr 2004
    5741
    Re: fusion360
    Have you checked to see if this is a feature they've dropped from the version you're using? The general strategy is to get people to use the program for cheap or free, then eliminate features to force them to pay if they want to keep using them.
    Andrew Werby
    Website
    Re: fusion360
    No I have not checked to see if this is the case. Id be very upset if this was the case. Where would i go to see if they have dropped this verion? Thank you for your reply.
    Nov 2014
    724
    Re: fusion360
    Can you export your f3d file and zip it, then upload it here for one of us to see how it works with the full-blown F360 version? It'll have to be in zip format to upload. You don't even have to really zip it unless you want to or if it's a large file, just rename the file extension type from f3d to zip.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Re: fusion360
    Thank you for your help.I'm at my end on trying to solve this problem.
    May 2022
    Re: fusion360
    Did you find the solution ?
    Dec 2013
    5717
    Re: fusion360
    Try selecting only the outside chain. Seems to work for me. Now why it doesn't work like before, I have no idea.
    Jim Dawson
    Sandy, Oregon, USA
    Re: fusion360
    Thank you Jim.I tried just selecting the outside chain with no luck then i tried the inside chain with no luck. I tried it on another computer that did'nt have the new update and it work like it did before the new update.
    Attached Files Attached Files
    Re: fusion360
    No mate still working on it.
    May 2022
    Re: fusion360
    Have you solved it yet?
    Re: fusion360
    No mate
    Jul 2011
    400
    Re: fusion360
    In fusion the engrave tool path is a bit misleading. Try using trace instead of engrave.
    Here is a video that explains it.
    https://www.youtube.com/watch?v=HKNbPPs-K2Y
    Dec 2013
    5717
    Re: fusion360
    I just took a look at your last posted part. It seems that the heights need to be adjusted to get it to cut correctly. Note the Bottom Height, this could be done differently. I would normally select the top surface and select the offset from there. But this still does not explain the difference between the older version and the new version of software. I have the paid version of Fusion 360, Ver 2.0.13162
    Jim Dawson
    Sandy, Oregon, USA
    Re: fusion360
    Thank you Jim for your help. I'm in contact with Autodesk they are trying to solve this problem, they are looking for solution over the weekend and will get back to me. Thanks for all the help. I will update the solution when it arrives.
    May 2022
    Re: fusion360
    Open the photo for laser engraving on wood, then resize and crop the photo to the final size you are going to engrave. Note: It's very important not to change the size of your photo once you convert the photo to a Black and White 1-bit photo in the final step of this process. I changed my all website(https://applicontech.com and https://www.mazuzee.com) photos in the same manner
    Feb 2023
    Re: fusion360
    It can be useful for you if you open Stick Merge on your mobile. It can activate your devices and help you have great experience.
  1. fusion360
    By happycnc1234 in forum Autodesk CAM
    Last Post: 03-19-2022, 04:58 PM
  2. Tiling with Fusion360
    By Project_Hopeless in forum Autodesk CAM
    Last Post: 05-12-2021, 10:49 PM
  3. Fusion360 post
    By yugami in forum Milltronics
    Last Post: 04-15-2019, 09:36 AM
  4. Rotary around Z fusion360
    By dbunyip in forum Tormach Personal CNC Mill
    Last Post: 01-04-2018, 12:41 PM
