586,555 active members*
3,445 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > LaserCut > How to choose a laser machine for cutting wire netting
    May 2022
    10
    Hi! Tell me what power of the laser source is needed for a 0.25mm thick wire mesh cutting machine, the mesh pitch is approximately 0, 2-0,4 mm.
    Feb 2022
    11
    Re: How to choose a laser machine for cutting wire netting
    hello , depend of your Fiber laser machine power and speed setting , one tip is set 100% power , pierce 0seg, speed start 20m/min and if it is well cutting increase speed , if not reduce each time 10%
    Best wishes and good luck
    suggest 1000w or 1500w fiber laser source
    fiber 1000w laser metal cutting machine cutting 2mm thickness stainless steel and 3mm diameter hole
