Im finally doing some more complicated machining other then 2 axis stuff and my knowledge is limited. Im trying to make a simple die that will shape the end of a tube. Im doing a surface rough using a 1/2" ball em but for some reason it wants to make the first cut the depth of the tool radius (.25") when I want all cuts to be only .05". I have checked all of the settings and cant find anywhere to change it. I have attached 2 screen shots, you can see the first tool path at the top of the parts is much deeper then the rest. Any help would be greatly appreciated.
Jim
BTW im using MCAM X the first version.....
