586,588 active members*
2,916 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Interface MPL3115A2 with an Arduino micro-controller
    Oct 2016
    15
    Hello, I want to hook up a MPL3115A2 pressure transducer sensor and interface it with an Arduino micro-controller. But I have a question. I could set up the display and I can see it is working. The problem is that I get some random numbers, regardless of connecting the sensor or disconnecting the Arduino analog input from it. What might be the problem? Even when nothing is connected to the A0 or any other analog pin, I see the same behaviour.
    I appreciate any reply and help.
    Mar 2015
    410
    Re: Interface MPL3115A2 with an Arduino micro-controller
    The MPL3115A2 has an I2C output, not analog.
    If you follow the directions on this video, you should get it running https://www.youtube.com/watch?v=sYA4GI0BXXET
  1. Replies: 1
    Last Post: 01-17-2022, 11:57 PM
  2. Replies: 0
    Last Post: 01-14-2022, 03:41 AM
  3. Mach3 ---> Brushless ESC interface with arduino?
    By skmetal7 in forum CNC Machine Related Electronics
    Last Post: 02-25-2018, 11:04 AM
  4. 109JB's User interface for the Arduino GRBL controller
    By 109jb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2017, 06:51 AM
  5. Replies: 0
    Last Post: 07-24-2017, 05:33 PM
