586,501 active members*
3,287 visitors online*
    Hurricane Laser Stepper Motor - Need help
    Hurrican Laser is out of business, I own a 60 W Floyd Model. I need to replace the stepper motor, the information on the motor says: Type 57BYG059JXF CW#120215. I contacted gweicke several times and they have said they would get back to me but didn't. Does anyone know where I can purchase this type of motor or does anyone know of an equivalent. I don't know anything about the steppers and there are so many types online. This one has 4 wires and a 1/4" shaft, and a gear wheel under it with 23 teeth. It is for the Z axis, the belt is 10 mm wide. Any help would be greatly appreciated! I have called numerous stepper motor resellers and no one knows anything about this particular motor.
    Re: Hurricane Laser Stepper Motor - Need help
    Also, this is my first post, so if I did it incorrectly I apologize!!
    how about add my whatsapp +8618560201508 then i send some 57 stepper motor data for you ,it should can be instead of old motor ,as we also make laser machine .
    Nov 2008
    643
    It’s probably nema 23 frame motor which is very common and available in many shaft sizes and lengths. Problem is that stepper motors don’t fail that often so it could be something else. I would check, tighten and clean all wiring connections first.
  1. Hurricane Laser Manuals
    By Bryan Rocker in forum Hurricane Laser
    Last Post: 10-17-2017, 02:49 PM
  2. hurricane laser support
    By JPBlake in forum Hurricane Laser
    Last Post: 10-15-2014, 08:01 AM
  3. Is Hurricane Laser out of Business
    By Bigbird48 in forum Complaints and Praise Discussions
    Last Post: 05-20-2014, 03:46 AM
  4. HURRICANE LASER
    By Rick Herbst in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-08-2013, 07:23 PM
  5. Need help from someone with G Weike / Hurricane Laser
    By bonedoc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-23-2012, 02:40 PM
