586,544 active members*
2,811 visitors online*
    Feb 2022
    12
    Hass controller
    I am trying thread milling operation in Hass controller machine. I checked all the parameters same as fanuc but my tool is broken on its first cycle two times.
    Any one suggest is there is unit mode setting in this controller?
    15362
    Re: Hass controller
    Quote Originally Posted by Manishpwn View Post
    There should not be any Parameters to change in the control, it's more likely the program is in correct
    What type of thread mill are you using, I have never had a problem with thread milling on our Haas machines, control is standard with factory set Parameters.
    Mactec54
    Feb 2022
    12
    Re: Hass controller
    Here is program
    O1001( 9.67X15.52NPT18 RPRG=4.394 )
    (T1 D=9.67 ZMIN=-11.724 )
    G90 G94 G17
    G21
    G53 G0 Z0.
    T1 M6
    S2928 M3
    G54
    G00 X0 Y0
    G43 Z5. H1
    G91
    Z-15.313
    G1 Z-1.411 F500.
    G41 X-3.615 Y-2.721 D1
    G3 X10.066 Y2.721 Z0.294 I4.665 J2.721 F56.96
    X-6.451 Y6.462 Z0.353 I-6.457 J0.006 F95.38
    X-6.473 Y-6.462 Z0.352 I-0.006 J-6.468
    X6.473 Y-6.484 Z0.353 I6.479 J-0.006
    X6.495 Y6.484 Z0.353 I0.006 J6.49
    X-10.019 Y2.877 Z0.29 I-5.423 J0 F57.92
    G40 G1 X3.524 Y-2.877 F500.
    G0 Z14.729
    M5
    G90 G53 G0 Z0.
    G53 X0. Y0.
    M30
    Feb 2022
    12
    Re: Hass controller
    Also i am using solid end mill with diameter 9.67mm
