586,655 active members*
4,415 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Swivel head for a R8 spindle on a bench top mill
    Jul 2005
    57
    Anyone heard of of a swivel head for an R8 on a smaller mill? The ones I'm fimding are too heavy and require a larger knee mill or machining center. I do quite a bit of firearm work that would be easier with a swivel at the tool rather than all the associated calculations with a tilting table. My mill is a 2hp Enco converted to cnc and the head rotates 360 degrees but doesn't tilt or swivel itself. The beast probably doesn't exist but I figure this is the place to ask.
    Rick
    Apr 2005
    1778
    Rick,
    Have you looked at the SX3, the RF45 or the Industrial Hobbies machines?
    Alan
    Jul 2005
    57
    Not really. I was trying to avoid looking at a new mill. It's something I can't really afford right now. I am trying to make various cuts from 22.5 to 45 degrees and setting up in an angle vise and figuring each successive cut is a pain for me since I am still a novice at cnc programming. Hitting dozens of small cuts manually is a bigger pain and extremely time consuming. Angling the tool would be a very simple solution. Then again, if I ever do figure out how to write the program and set the piece up in the jig, it would be pretty simple as well.
    Rick
    Apr 2005
    1778
    Rick,
    Take a look at this thread. Dan (Hoss26) made a rotating/tilting head for his X2.
    http://www.cnczone.com/forums/showthread.php?t=30385
    I would suggest reading his whole thread, but specifically look at message 279.
    Alan
  1. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
  2. My bench-top Mill plan.
    By KCress in forum Benchtop Machines
    Last Post: 11-01-2006, 04:24 AM
  3. bench top mil with Cat 30 or 40 spindle
    By triump in forum Benchtop Machines
    Last Post: 10-17-2006, 03:54 AM
  4. A new bench for my mill.
    By yukonho in forum Benchtop Machines
    Last Post: 12-30-2005, 01:35 AM
  5. Bench for a Benchtop Mill
    By Novah in forum Benchtop Machines
    Last Post: 10-28-2005, 03:50 AM
