586,494 active members*
2,629 visitors online*
IndustryArena Forum > CAD Software > Autodesk > write protected dwg
Results 1 to 10 of 10
    Sep 2007
    4
    Angry write protected dwg
    I have picked up an architectural design project. The client has ditched his original architect ( on speaking terms). He is fully paid up and has asked me to take the project to the next stage, so I am not poaching here!
    He has e-mailed me dwg's of the project in its current form. I need to make changes (to show more detail and text etc) but the dwg is write protected and so I can't save any changes that I do make.
    Is there any way I can 'unprotect' this? (file/properties/ uncheck the box won't work 'cuz the box ain't checked!)
    It would be a massive amount of work to re-draw.
    Cheers,
    Smudger.
    You mean it's marked "read only"?
    24223
    Like Gerry mentioned, right click the file and look at 'properties' and uncheck read-only, many times when DWG are copied to CD etc, they are set to read only in this manner.
    Al.
    Sep 2007
    4
    Angry
    no, its write protected. When I try and save the changes I have made, a box pops up saying 'this file is write protected'
    Jun 2005
    40
    Try to save it to another name. It may just be the original file is protected to keep it from being modified.
    Jul 2003
    1754
    Is there a dwk file in the same directory with the same name?
    sam
    Sep 2007
    4
    Cheers darde,
    that seems to have done it.
    Simple really!
    Samco, no the wasn't. But thanks anyway.
    A quick search of AutoDesks forums says uncheck read-only. Or, try to wblock the entire drawing and see if that works.
    Sep 2007
    4
    Thanks gerry,
    all sorted Mate.
    Jun 2005
    40
    No problem we get this all the time when we open someone elses drawing through the network. We can't save it back to there computer but we can save it to our own. It is just a safter so other people can't modify your original drawing.
  1. O9xxx Protected Programs
    By John3 in forum Fanuc
    Last Post: 08-11-2007, 02:59 PM
  2. Possible to write variables to a program?
    By Heavy D in forum G-Code Programing
    Last Post: 08-22-2006, 05:08 AM
  3. L50 parameter write
    By Bluesman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2006, 12:49 PM
  4. write protected
    By stevieboy in forum Autodesk
    Last Post: 06-03-2004, 09:03 AM
