586,371 active members*
3,223 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 300 lathe turret alarm
Results 1 to 20 of 27
    Sep 2007
    Can anyone help me clear Turret alarm 2047 from my Daewoo Puma 300 Lathe?
    May 2006
    265
    Replace the backup battery in the turret servo control, and re-program it..
    Puma in swedish = Nice looking blond with big tits..
    May 2006
    265
    Here is how to do it:
    First replace the battery in the sevro unit, it is located in the eletricalcabin in the back off the machine. It s the white box on the right side, I think you can read servo unit on it... The battery is located inside the servo unit so you have to disamble it ti change...
    The battery that ive got is from Tekcell, SB-AA11 Lithium 3,6Volts size AA and can handle heat of 212F...
    First unclamp the turret. You will do this by changing keeprelay parameter
    k5.4 to 0..
    Set PWE to 1
    SoftKey PMC
    softkey PMCPRM
    softkey KEEPRL
    K05 00001100
    Change to
    K05 0000 0 100 to unclamp turret..
    Manually index tool 1...
    CHange keeprl 5.4 back to clamp turret...
    Now it is time to set the encoder zero-pont. just follow the attached docs to achive this... It is done on the servo unit....
    Hope this will help you out... It works for PUMA 300 MB from year 2001/02 or something...
    Edit: You may try to set the zero point without changing battery, The servo might just been bored too..(Happend once to me)..
    Sep 2007
    Have a Daewoo 240L with 2047 alarm.I have replaced the battery twice but cannot get power to the servo unit to reset the parameters.Anyone have suggestion.
    May 2006
    265
    Have the main power ON..
    Sep 2007
    MR M-man it is on.
    May 2006
    265
    The servo unit might have checked in for good...
    did you get the 3.6V battery?
    Sep 2007
    Yes I did get the 3.6v battery.Can't figure it out broke down and called the repair lathe guru.
    Oct 2007
    30
    Smile Fix to alarm 2047
    I actually had this alarm happen to me as well. I pulled off the rear back cover of the turret and there is a proximity switch back there that has yellow led usually or green. Stick your screw driver in between the switch and the contact. Move the tool position on the control at least a few tools away from where you are stuck. Then hit index button and quickly pull your screw driver out. Sometimes you might need two people depending the distance from proximity and the control. This will reset and turret will lock back in place.
    Worked for me.
    Bdyenter
    Jun 2009
    20
    hi,maybe i can
    lll
    M-man your steps is OK i did this before many times, but i prefer to press the EMG button, so the turret is free to index manually instead of changing Keep relay
    sting
    Nov 2008
    Hi I have same problem on Puma 230 M
    sometimes issue alarm "2047 Turret clamp switch alarm or turret control unit alarm" i chek clamp sensor it`s work fine.Тhe other thing I noticed is when issue 2047 alarm indication of servo is
    Pro..Ct
    Pro..150
    P..Con
    This something like restart of servo or i`m wrong?
    And when press "RESET" key turret is rotate
    Jun 2009
    20
    hi,how r u
    Quote Originally Posted by Carl_Cox View Post
    Pro..Ct
    Pro..150
    P..Con
    please check the cable conect the amp L1 L2 L3 ,maybe cable loosen! or the electric circuit not output the 200 voltage!
    May 2005
    109
    Hi M-man,
    When turret servo's battery went out I replaced bat, but now the turret turn 1/10 for 1 tool ( actually it must be 12s). Could you help me fix parameter for this problem?
    Machine: puma 300
    Turret drive: Doosan Pro-Motion DASD-CT15SPXC-05
    Thank you very much.
    Jun 2009
    20
    hi,can u tell me your email?
    Dec 2013
    Did you get this problem sorted I have exactly the same problem?
    May 2005
    109
    You have to change Pro-Motion parameter. If you have Pro-Motion manuals, send me a copy (I don't have).
    Jul 2014
    4
    Re: Daewoo Puma 300 lathe turret alarm
    how to change keeprelay parameter K5.4 to 0 in daewoo puma 230 ms cnc lathe machine.
    the machine is due to 2047 alarm.
    plss give replay friend.
    Feb 2013
    788
    To change K5.4
    1. Enable PWE (Parameter Write Enable)
    2. Be in MDI Mode
    3. Press <SYSTEM> Hardkey
    4. Press<RIGHT ARROW> softkey. until PMC appears
    5. Select PMCMAINT or PMCCONFIG for the choice "KEEP RELAY" (depends on the control software)
    6. Highlight Keep relay 5 bit 4 (Note: Bits read 76543210)
    7. Alter
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    Doosan Servo Pro-Motion CT Manual attached
    Attached Thumbnails Attached Thumbnails Doosan Servo manual_061011.pdf
  1. Daewoo Puma 230 Turret issue
    By atscnc in forum Daewoo/Doosan
    Last Post: 02-04-2022, 01:53 AM
  2. Daewoo Puma 450 A/B Lathe
    By scater1j in forum Daewoo/Doosan
    Last Post: 07-29-2010, 02:46 PM
  3. turret is lost on a daewoo puma 12 lathe
    By tnik in forum Daewoo/Doosan
    Last Post: 07-02-2010, 12:34 PM
  4. Daewoo Puma 12L Hydraulic Turret
    By MysticMonkey in forum Daewoo/Doosan
    Last Post: 07-08-2009, 09:44 AM
  5. Daewoo Puma 700 LM - Lathe
    By Kim in forum Daewoo/Doosan
    Last Post: 04-18-2008, 07:18 PM
