586,501 active members*
2,676 visitors online*
Results 1 to 12 of 12
    Jun 2007
    22
    what type vfd is this saftronics?
    Can someone tell me the make and model of this? I need the manual.
    Aug 2011
    121
    Re: what type vfd is this saftronics?
    Yaskawa VFD of some type? Is there a label on the side with a CIMR-*** number? From what machine was it removed?
    RT
    Jan 2005
    15362
    Quote Originally Posted by marauder View Post
    It will have the model number on a side Name plate this is a very old drive, Saftronics where brought by Emerson Industrial Automation in 2005 Emerson’s Control Techniques division
    What machine is it on, you will know also by the motor it was driving as to it's specs also.
    Mactec54
    Jun 2007
    22
    Jun 2007
    22
    Attachment 477652 Attachment 477650 it was on the side almost touching the electrical cabinet.
    Jun 2007
    22
    lagun cnc mill 310
    Aug 2011
    121
    Magnetek Lancer GPD502. Search for GPD502 on the Yaskawa America website, you will find the tech manual.
    RT
    Jun 2007
    22
    Jan 2005
    15362
    lagun cnc mill 310
    What are you wanting to know about the drive, is it working or do you want to run it on single phase.
    Manual attached
    Attached Files Attached Files
    Mactec54
    Jun 2007
    22
    the crt went out on a lagun 310 cnc mill. I just wanted to start the spindle up to test the the spindle, and Baldor motor. The drive turns on, But the remote light turns on. and i can not start it using the keypad on the vfd. Thanks for the manual. Do you know how to change the drive from remote to manual control with the keypad? Its wired up to 3 phase.
    Thanks ( I haven't read the manual yet)
    Jan 2005
    15362
    Most of these older VFD Drives you can change the drive mode with the keypad the led at each function will light up this indicates the mode you are in, and you should then be able to run in manual mode even Jog mode should work this will Jog the spindle at a preset speed.
    Mactec54
    Jun 2007
    22
    Thanks mactec54, I read the manual. and found out that i had to change sn04 from 0000 to 0001. its running nice and smooth.
  1. Saftronics G3 issue
    By EmeraldIsleforg in forum Spindles / VFD
    Last Post: 08-01-2020, 01:24 AM
  2. VFD wire type
    By HalfRhoVSquared in forum Spindles / VFD
    Last Post: 03-18-2017, 11:28 PM
  3. saftronics spindle drive inverter
    By fcycles in forum Want To Buy...Need help!
    Last Post: 02-11-2012, 06:04 PM
